1 - 3 of 3 Posts
Le Troll
I'm looking in to getting a motodynamics integrated tail and flushies. I'm just wondering what wiring is necessary and if I will need a relay.
Where do I find a relay if I need one? What do they do? Tried searching but not a ton of luck...
Thanks,
Sean
faster than a turtle XP
some brands have the stock connectors on there front flushies so plug and play, the tail light is plug and play as well as the only thing youll need are wire so that the labeled left and right wires on you tail can be tapped into the oem connections for power. now the relay is so that your blinkers do flash super fast and are brought back to DOT approved speed.
The motodynamics tail is completely plug and play. No additional wiring needed.
1 - 3 of 3 Posts
