1 - 4 of 4 Posts
· Banned
well it actualy comes down to wether you have 2 wire or 3 wire lights. if you have 2 wire you wont have runnin lights, youll just have blinkers. but other than that its pretty straight forward. either butt connect (huh huh i said butt connect) the proper wires from the bike to the lights or sauter them. i cant remember the exact colors for the rear ones but i belive theres green, brown and black. black is ofcourse the ground wire, green and black are the two different power wires, but i dont know which controls the blinkers and which does runnin lights. you can find out by doin temp connection by twistin them together and turnin on the lights. if the blinkers are brighter then the runnin light you got it right, if not switch and try again. hope that helps.
If you have the gregg's flushmounts you can still have running and signals. Skip the ground wire and wire the other two wires. You'll have running lights and signals. But you probably want to install a relay to slow the blink rate because it will blink crazy fast.
1 - 4 of 4 Posts
