1 - 8 of 8 Posts
So after crashing at the track I decided to do the best I can to protect my bike/motor in case of another crash.
I bit the bullet and bought a whole lot of Woodcraft Bling :toocool:
So the question is can anyone tell me what step #3 is on the attached instruction sheet?
http://www.duncanmoto.net/pdf/products/woodcraft/engine_covers/60-04xxrb_it.pdf
I removed the stock cover and there was nothing "attached" to it. What am I missing?
I'd Flip it :popcorn:
On mine, I have a Hose that runs over the top of the cover, there is a Holder to keep it there..Same on the bottom with a vent hose
on the stator cover - there's a wire harness through the top. then it runs under a "clamp/holder" thing that is held in place with one of those torx bolts. that's how mine was. i actually stripped the bolt trying to get it outta the stocker so both the bolt and clamp/holder thing were stuck in the stocker. :( ordered new of both from ron ayers, and went on with my business. good luck.
Thanks Guys, I read to much into those instructions...:dunce:
we'll see how it goes with the timing chain cover later today
any ideas on how to remove/replace the rear shock? I can't find a clear how to guide
i hear it's a joke... just a bolt or two, and you drop it. the top nut is under the tank. pretty easy to get to once the tank is off (i think that's about it). good luck man!
Yeah It is under the tank, VERY easy once the tank is off, I had mine off last night. And took me less than 15 min for the whole deal
Do you have to take the weight off of the rear? I would think there is some compression going on in that spring
1 - 8 of 8 Posts
