Maybe a newbie question, but why? I was under the impression it was to your advantage to have it?
Sorry I do not know what question your asking,
Is it an advantage to have the EXUP remover?
or
Is is an advantage to have the Exup hooked up?
It depends on the situation,
if you have a full aftermarket system then you do not need the Exup motor to work but if you disconect the plug from the factory harness then it will throw a code in the computer and you will have the light on the dash on.
That being said if you have the Exup remover relay then you can fully remove the motor saving a little weight and getting rid of the useless motor on your bike. And the relay will trick the computer into thinking that there is a Exup motor and not throw a code.
Is it an advantage to have it hooked up with factory system? Yes, it creates back pressure and regulates the back pressure at most rmp ranges helping with the bottom to mid power that the R6 struggles with in the first place.
If removed will you notice a diff with the factory system, I beleive probally not.
But who am I, I have no hard evidence or facts to back that up, someone on here mite know for sure.
Hope I helped.
