This is the (black) left side caliper mounting bracket that also serves as a front fender mounting bracket. It is also the front axle holder. It is located at the bottom of the fork. It is not pressed on. It unscrews from the fork, so it can be removed from a bent fork. It’s mounted with Loctite, so a little heat may be required to remove it. I believe this bracket is the same for several years of R6’s.
Again, I do not need the fork, just the bracket.
Please contact me at (714) 209-6558 or email at [email protected]
Thank you
