1 - 8 of 8 Posts
I would recommend an ECU flash to get rid of the code so you don't need anything; you don't need the eliminator or the cable.
Also, you wouldn't have to get a PC5 as flashers can put in a map based on the mods you do, and they're pretty spot on.
Ow ,NuckenFuts
So with a flash I won't even need the eliminator... that's good to hear. That is the route in going to go. Let you guys know when things are done. Mac7504 I havr the cables wrapped up on the inside of the frame. Out of sight out of mind. I'll hit you up when I decide to install the mid pipe.Thanks a lot guys for the advice.
1 - 8 of 8 Posts
