Hello, to begin with i bought myself an R6 2005 with some electrical problems. When i bought it there were some error codes on the dash 20 and 30. I rewired some of the wires because they were hard as rock and breaking everywhere plus current rectifier connector was melted down. As i said i rewired everything, connected everything was ready to start but 3 error codes were came up on the dash the same 20, 30 and 11. What seems the problem as i checked every wire from top to bottom i rewired some of them, checked the error code 30 lean angle sensor, changed it to new one but still same error code 30. Any help? Ohh and also if that helps when i try to start the bike i press starter button, starter relay clicks and check engine light comes up and the motor won't turn like it seems as a dead battery but i double checked that the battery is new and the voltage is normal.
