1 - 3 of 3 Posts
Hello, i just bought r6 with this problem where i cant down shift two gears at once or sometimes i cant shift down at all. I have no problems with shifting up. When bike is off and it is in 3rd gear I can shift down to 2nd but lever stays at lower position and i cant shift into neutral or first.
there's a spring inside the shift shaft cover that may be broken. you may want to try lubing all the pivot points and the lever first. just to make sure nothing is binding.
1 - 3 of 3 Posts
