1 - 4 of 4 Posts
she already got me broke
i `ve got as 2005 yzf600 running in 3 cylinders, i know this is mostly R6 website related but this bike has similar specs. i pulled out carbs and cleaned real good, and after install em the bike is running in 3 cylinders, cylinder #1 its not running i have sparks but the exhaust pipe keeps cold. what you think could be one cylinder its not working?.
passion 4 bikes
could be the coil packs braking down,it happened to my fzr 400 one of the header pipes was cold and running on 3 pots changed the coil packs and it was ok also replaced the spark plugs.
i got it fixed guys. thanks anyway. finally the problem was a carb not really cleaned. so i repeated the cleaning process with better results.
1 - 4 of 4 Posts
