Last year I put a new fuel filter and air filter on my 2001 r6 just because I figured it could use that. It wasnt running right after that. Hesitating alot when on the throttle but would idle fine. I thought maybe something got loose and went in the carb when I replaced fuel filter, so I took carb off and cleaned it. First time I cleaned it it ran the same way. I cleaned it again cause I kind of did a half ass job the first time and it wouldn't start at all. That was last year and I am finally getting back around to it. I have the whole carb off and disassembled and I am replacing the spark plugs. I looked at the fuel pump and that looked fine. Is there anything else i should do while i have it apart or anything leave I shouod consider? Anything I should replace on the carb or anywhere else? Thanks
