Anybody set up a left hand rear brake control on their R6?
I have it on my Hypermotard using a Qnium rear master that replaces the brembo, and a Magura 16 left hand brake master.
I am considering setting up a similar unit on my R6. I plan to use the Ho Hey fitting that installs in the existing rear master reservoir port, and run a magura on the left clip on underneath the clutch. Some go the thumb brake route but I find that to be an unfamiliar method to apply brakes.
The HHD Rear Hand Brake Fitting (Must Select Red or Green in Order Options) - $60.00 : HoHey Designs, Custom and Factory Parts for stunt bikes
Magura HC1 Left - 16mm Master Cylinder w/Close Reach Lever - $234.99 : The Sic Shop, Stunt Parts Store
https://www.qnium.nl/
