The Bike: 2006 Yamaha R6
The blinkers: Rizoma LED's, front & rear for turn signals, both a 2 wire set up.
Flasher Relay: Custom LED Flasher Relay & Magic Blinkers
Situation:
I've already installed the flasher relay so I'm not sure why I'm having this issue but this is what I've got.
Rear turn signals work great, no problem there... until I hook up the front LEDs.
When I hook the front signals up I can choose between using them as running lights or blinkers. When hooked up as running lights the LED is at full brightness. When hooked up as blinker the LED is at partial brightness (I'm assuming due to flasher relay).
Insert Magic Blinkers to convert 2 wire to 3 wire.
I've tried running these multiple ways but either they don't light up at all (wired incorrectly) or they stay lit (wired correctly?).
When the front LED's stay lit the rear LED's ALSO act as running lights. Turning to partial brightness then to full bright as the blinker strobes on and off.
I've tried wiring it w/ a resistive load before and a resistive load after the Magic Blinker but to no avail. Got an e-mail into CustomLED to see if they have any pointers but I figured I'd throw it out to the forum too.
Any help is appreciated. And yes, I know I can just say fcuk it and go without running lights but I'm trying to keep it as legal as possible.
Situation:
