Status
Not open for further replies.
101 - 120 of 456 Posts
post 97 u said u were checking the TPS in the diag mode, ok cool.. i was telling u it will only do it once, then u have to start the sequence again.
U dont have to be / or shouldn't be in the diag mode to calibrate your TPS for the PCV, from what your saying it wont start. Just start the bike like u normally would, hit reset, WOT blips and save.
What was your TPS% saying when u watched it live?
Save
Percentage shows as zero when I do it. It shows the voltage up to 0.733 or something, but no throttle % at all.
The other issue was that the bike won't start at all. keeps chugging but doesn't turn with either PCV plugged in or stock ECU in.
it will only pick up the TPS when the bike is running.... so gotta fix that first. i responded in your other thread. might have to reset the bike in the diag mode, thats what i had to do.
Save
Hey Ohio... You have the ignition module and quickshifter?
Save
Discussion starter · #105 ·
No, I've looked into it and for as much as it costs I think I will go to a flash tool or YEC ECM, as that ignition module is expensive.
Save
where do u get the flash tool? YEC ECM?
I just purchased, and currently installing the Ignition Module and Quick shifter. So, was curious to see what setting u had.
Save
So I've fixed the code error and starting issue (thanks to Ohio and Minnesota) but now I have to configure the TPS..... I tried to put in the default values that Ohio suggested but it doesn't appear to be reading.
It looks like I have to use Minnesota's recommendation and do it while the bike is running. Because whenever I try to do it in Diag mode, the throttle sensor only goes to 50-something once, not reading in the PCV software, and when I switch it off/on the code 14/15 appears again.
If I wipe it it starts again. So Minnesota: Did you just start the bike normally with the PCV plugged in your computer, then open the TPS callibration tool in the PCV software?
So bike is running, open callibration, clear what appears, then open the throttle full, hit okay, turn the bike off/software should pick it up automatically?
I just want to try it once because when it was running the software was showing throttle at 100% (it was just idling) and the AFR was up in the 16's so I shut it off. I didnt want to let it run with it reading that high. But the AFR/RPM was reading when I pulled the throttle a little bit.
I'm using Ohio's PCV map and AFR table.
yea.. the voltage got messed up in the TPS cal it looks like when u were messing with it so thats why its showing 100%..
Dont even worry about the DIAG mode on the bike anymore(for this).. So yea, have everything all plugged in, let the bike warm up, have your computer going so u can watch, open the TPS cal box, click on the reset button, blip the throttle WOT for a quick sec then save it.. Dont hold the throttle down to try and get the bar to move all the way across the cal box,,, it wont. Have you found this to read up on yet? And the AF's in the 16's isnt that bad.
open below link and click "To Calibrate the Throttle Position"
http://www.powercommander.com/powercommander/Support/Help/wwhelp/wwhimpl/js/html/wwhelp.htm
Save
Awesome.... worked great. 0% throttle when closed, 100% when open. And the AFR isn't as high.... it hovers around 13.5 to 14 but sometimes up to 14.5 at the highest (but not often).
Would it matter if I lowered my AFR target tables?
Mind you, this is warmed up in the garage. I need to take it around the block (but this is for track/racing so I will likely need to take it up there in a few weeks to play around with it). It still smells rich though.
Although the voltage on the TPS was noticeably lower than what was on here. 0.645 minium, I forget what the max was but it was lower than Ohio's 3.991).
Although the voltage was noticeably lower than what was on here. 0.645 minium, I forget what the max was but it was lower than Ohio's 3.991).
The TPS voltage will vary from bike to bike.. the AF will bounce around a little bit, wouldnt worry about it as long as its not surging.
Save
Discussion starter · #111 ·
There's a company out of California making a device that allows you to tune, flash and modify your factory ECM, very similar to the YEC. It allows for changes to the fuel tables, throttle maps, ignition timing. I need to ask them if it has quick shifter functionality like the YeC. Currently this box is $400, but can be used over and over on multiple bikes. I've been hoping it would drop in price some after it had been out for a while.
Save
gotcha... wish i would have looked around more, didnt know what was out there and the DynoJet stuff was all i read about.
Save
well.. installed the Ignition Module and Quick Shifter.. Man that QS is fun!
Added 4 degrees of time at 100% and 2 degrees everywhere else, felt damn good and quick!
plan is to run 102 race gas and bump it up to 6 degrees, hitting the drag strip on Saturday.
Save
OhioYJ.... after installing the MJS exhaust and letting it run, did it emit an odd/fume smell? I'm thinking it could be the powdercoat burning through.
Either that or it's running lean/rich. I haven't accepted any trims on the PCV/AT (if I do I would rather do it after a session at the track). I have the MJS map + the 13.8 to 13.0 starting AFR table you have in the first page.
Discussion starter · #115 ·
I don't remember any odd smells, on any of the MJS headers I've installed, but my nose isn't overly sensitive, so unless it was really strong I wouldn't have noticed.
Careful about accepting trims all over, you'll have a few spots that will continue to want.to go rich. I tend to only make adjustments to the cells that I think actually need adjusting. I also tend to throw the different maps and trims into a spreadsheet to compare the changes to, sometimes helps me analyze the data.
Save
Good advice. There's a free dyno-run day at a local shop this coming weekend.... I might have it go for a run and see what the results are when they come back.
Discussion starter · #117 ·
Also be careful with dyno results, as the dyno won't include the ram air effect.on our bikes, so it wont be entirely correct either.
Save
Could it have anything to do with start up fuel? I haven't set any of that.... any recommendations? I would be using the time-setting (not temp).
Discussion starter · #120 ·
So far on the R6s and CBRs I've worked on, I've never used the startup fuel. I also use the time delay not temp.
I would give it some run time and see if the smell goes away, could have been just something in the pipes. If it was really way rich or lean it should show up in your trims.
Save
Status
You have insufficient privileges to reply here.
